Fan setup. Carbide 400c
2 Aug 2017
I'm working on my fan setup inside of Corsair Carbide 400c. I have it currently going as shown on picture provided. Would you guys leave it as it is or change something.
Edit: im on mobile and i messed up the picture i think, let me know if you see it
VMFc9Xoeif91sTnc9
VMFc9Xoeif91sTnc9
VMFc9Xoeif91sTnc9
VMFc9Xoeif91sTnc9
No pictures.
Describe your set up.
Ok so:
OUT: Back 120mm fan + x2 120mm from Corsair H100i Pro XT on top of the case.
IN: 2x 140mm in front
Perfectly fine.
I would be tempted to change the back fan to an Intake so the aio is getting cooler air.
Probably would t make much difference in temps.
Perfectly fine.
I will try that. Also probably stupid but should fans on radiator be mounted on top of it(touching the case) or below if i am using them as OUT
