- 2 Aug 2014
- Watford
picked up a new case today the nzxt phantom 630 but not sure how i should set up my fans with my loop.
wc stuff i have 1x360mm, 3x240mm rads, gpu block, 150ml res, ddc-1t 10w will be getting a second pump to help with flow.
fans are stock from the case 200mm up the top, 200mm on the side , 200mm front, 140mm rear, will also have 2x120mm at the bottom for my rad.
would i better having all fans as intake with the 140mm as exhaust.
i will start a build log once i start taking my parts out of the old case.
