- 23 Oct 2010
- Telford, Shropshire
Gents I plan to install my H60 onto my top gtx 480 and use a gelid tranquillo for the cpu. (I7 920 at 3.8)
Heres a pic currently...........
My concern is the heat from the cpu getting pushed through the h60. Think this will be ok?
The H60 as a dual fan setup wont fit any where else in the case, unless I mount it in the front drive bays, although I dont really fancy all that heat in the case.
Currently I have the H60 at the rear exhause, 2x120mm in the top and 2x 120mm blowing in. One at the front and one at the bottom.
Coolermaster 690 v1 case.
Do you think the gelid will fit?!? Opinions please.........
