Fan shrouds?
10 Oct 2003
Nottingham
Are these available to buy anywhere or would you have to make one yourself? Just got a ft01 silverstone case and am thinking it would be good to have a fan shroud for the cpu fan pointing 45 degrees diagnoally down to pick up rising cool air from the intake
Any thoughts on how best to make one (look decent as well given window) if they cant be bought? Or would a hardware store have something that would work ?
Thanks
you could try making some ducting with some plexi. i'm planning on channeling air from the front intake to cool the vrm's and gram on my gpu's
tbh i'd just get a few sheets of it, cut out rectangles, glue it all up instead of getting properly moulded stuff.
have you got anything obstructing where you would put ducting/shrouds? i have the predicament of having to fit the plexi over my w/c kit, as the tube to the pump will be in the way.
my old housemate once used some of that tumble drier hose as ducting - did the job but looked hideous!
