Fan speed and water temperature question
I use a program called Argus Monitor to control my fans and pump.
https://www.argusmonitor.com/
It's really good and you can set a custom curve for both CPU and GPU. I think you get a month free trial then it's like £10 for a 3 year license (on offer at Christmas).
I have my fans and pump silent until my CPU hits about 60-70 for 25 seconds and my GPU hits 55-60 for 1 minute. This stops the fans ramping up and down and really only kicks them in when the temp is sustained.
Yeah I use Argus Monitor too, good software.
In terms of when they should start ramping up though, that will need some experimentation to determine, it depends heavily on your individual setup.
Put both your GPU and CPU under 100% load since you need to plan for worst-case scenario, not just average load. Monitor the water temperature and CPU and GPU temps with whatever fan speed you have now - see if they eventually level off before your GPU or CPU reach a temperature higher than you are happy with. It could take a long while for the temperature to stop climbing, a 5-10 minute test won't be enough here.
If they get too warm and the water temperature is still climbing, make a note of what temperature the water was when that point was reached. In my case for example with a Corsair H150i AIO (yeah I know, AIO, not "proper" water cooling, but the same principle applies) if the coolant reaches 40c, then my CPU starts to hit over 80c, which is more than I'm happy with even though it's not going to actually throttle.
Make that temperature your target maximum, then work out what fan speed you need to not exceed that under 100% load - experiment with setting the fans at different static speeds (e.g. lock all fans at 50%, or 70%, or whatever). That should then be the maximum % you need to set on your fan curve, for that water temperature. Again in my specific case, that means the CPU fans at 90% at 40c - you might well need lower depending on number and size of radiators etc...
If on the other hand your water temperature already stops increasing before your GPU or CPU get warmer than you want, you can afford to reduce your fan speed and have things quieter - experiment with lowering the maximum until you find a suitable limit.
Once you know your target maximum fan speed, work out a suitable minimum too. This time leave both the GPU and CPU idle, and try locking the fans at various speeds until you reach a point at which they are inaudible to you - in my case I can't hear them from where I sit when they are at 35% speed, which is about 500 RPM. Locked at that speed at idle, the CPU coolant in my setup sits at 35c.
See what water temperature you get with the fans locked at that virtually silent speed, and make that the minimum for your fan curve.
Finally, just define a smooth ramp between the minimum and maximums you determine - if you have it fairly linear the fans should increase (or decrease) nice and smoothly without big jumps in speed which will be noticeable.
As an example, here's my fan curve for controlling the speed of my case fans depending on my GPU temperature:
I found that my GPU won't go over 45c when just using standard desktop apps (not playing video or games) even with the case fans stopped entirely, so I turn them off completely below that. Then just 20% at 45c for a nice quiet start, rising smoothly to 40% at 75c - my experimentation showed they don't need to be higher than that to keep the temperature under control.
I set a fairly steep rise after 75c just in case things start overheating somehow, but in practice I never reach that point under usual gaming load - the temperature stops climbing before it reaches that point.
Aquacomputer QUADRO or OCTO, then you control all easily, plus a complete fan controller.
For D5 pump, never noticed any benefit changing pump speed. Usually quiet up to 40ish %. Mine is quieter at 80% than anything between 50 and 75%. You may need to try and then keep the pump at a static speed.
I wouldn't recommend lock any fan to CPU temperature, as the spikes would force the fans to speed up and down all the time.
Best to control everything based on coolant temperature. Even if you decide to use the motherboard for the fans, if your motherboard allows a temperature sensor, I would use it.
Without knowing your full setup, it's hard to recommend fan curve, etc
So I can control an EKWB pump and fans plugged into mobo header with this software? I want to make the fans ramp up as soon as the GPU hits 50c
Hi
ok so when should my fans start ramping up?
my GPU is usually sat at 45 degrees.
I have a d5 pump.
Cpu in the loop too.
It sounds like your asking when your fans should ramp up rather then with what? if so IMO wherever you find a happy medium noise / temp wise. Once you get past a certain point, need to really crank up the fan speed (hence noise) to shave the last few degrees off. GPU sat at 45 under a typical load is okay if noise is also fine IMO.
Yes - grab the trial version and see for yourself.
It can also control fans/pumps based upon more than one different temperature source, each with their own curve.
In my setup, the case fans are only controlled by the GPU temperature, but the CPU fans can ramp up based on either the CPU coolant temperature OR GPU temperature. I have it that way since the CPU fans are the main exhaust from my case.
