Hi, i have two 120mm Akasa Amber fans cooling my HTPC and was hoping to find some software to allow me to control their speed as they are plugged into the motherboard.
Unfortunately, my mobo manufacturers (MSI) software doesn't work on Vista x64 so i can't use that. So does anyone know of a decent bit o' software that will allow me to control fan speeds in Vista x64?
The BIOS is pretty pants and only allows control of the fan via CPU temps that are over 40c, and it normally sits at around 25-30c so i can't get them any slower via that. They're usually spinning at around 1500RPM but its slightly too noisy sometimes.
