I want to use a multiple fan speed controller on my new build am wondering if there are any that don't lose much speed on maximum when using non PWM fans?
In the past I've used 1200 RPM fans each with a Fan Mate 2 and in that case the speed can be varied up to about 1100 RPM. In the new build I want them all controlled by one controller and may want a couple of fans to run nearer to 1200 RPM (1300 if using NF-P12) and if all controllers lose about the same then I'll need to get 1500/1600 RPM fans instead.
I would be grateful for any information about which controllers are good or bad in this respect.
