Fan speed not showing
19 May 2025
Greenock
I recently upgraded to an ASUS RX 9070 XT Prime, and I’ve noticed some concerning behaviour:
  • While playing Fortnite, the GPU memory temperature reaches up to 92°C, while the core stays around 69°C.
  • In AMD Adrenalin, I can control the fan curve, but the fan speed always shows as “–” (not displaying actual RPM).
Is 92°C memory temp within expected range under load, or should I look into improving airflow or undervolting? Also, is there a fix for the missing fan RPM in Adrenalin?
Thanks,
Fabian
