Fan speed / placement.
19 Nov 2015
Glasgow Area
I ordered two new fans for my case. both 120mm.
Im replacing a fan at the front of my case and a fan at the top of my case.
One of the fans I bought is PWM and 1 isn't.
Any suggestions which to put where? and then the second part, where to plug them in?
I can plug into SYS or CPU header. Both SYS or do I want the one at the top of the case into CPU? and if so I guess that should be the PWM one?
I don't care about noise at all (always have headphones on). I find modern quality fans not noisy at all anyway even at full speed.
Thanks as always.
