15 Apr 2008 at 18:34 #1 GingerNinja1989 GingerNinja1989 Associate Joined 6 Dec 2007 Posts 2,103 Can anyone reccomend me a program to control fan speeds etc from windows? I really can't be bothered with the long winded way lol. Ta
15 Apr 2008 at 18:38 #2 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Speedfan is best, if you have a newish Mobo even a 680 age or newer, then get latest Beta (final is due anytime). Advise you read the inc info and learn to Config and fact you can rename any aspect and control Fan by Temp you set limits to and Fan Min/Max Limits. Example FAN1 can be made to CPU FAN = far easier for you.
15 Apr 2008 at 19:04 #3 GingerNinja1989 GingerNinja1989 Associate OP Joined 6 Dec 2007 Posts 2,103 Right, goodo. My board is P35 based. Still good for the beta? And thanks.
15 Apr 2008 at 19:32 #4 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Yes as the last Final build is bit older and wont read settings correctly on many Mobo's.
16 Apr 2008 at 01:11 #5 GingerNinja1989 GingerNinja1989 Associate OP Joined 6 Dec 2007 Posts 2,103 Ok, thanks for the info.
