Fan speed?
15 Oct 2006
I just got my arctic freezer and it's great, although i put Q-Fan enabled and its runnin at 1000RPM, the temperatures are 49 idle and 55Load. I want to put the fan speed slightly higher so maybe both temperautres can go down slightly?
How do i go about doing this, in speedfan i put the %'s up and nothing seems to change.. also should i really bother doing this? the Pentium D's are hot anyway
Will you be overclocking?
You really shouldn't get hung up on how low the temps are, 55c is perfectly fine load and it is nice and quiet. If you are going to be overclocking then disable Q-Fan and use speedfan to control it from windows.
