I can't work out why my PC gets really noisy when gaming, i initially thought it was my graphics card so i fitted a fan mate.
My case fans are all going direct to the power supply not motherboard... and have manual speed control.
Temps after an hour of playing GTA4 are only around 40c and 25c idle on the desktop.
The CPU cooler is PWM and i have smart fan enabled, even set ideal temp to 65c and level 1 to try achieve the least possible noise level.
CPU fan is running about 1200rpm idle and gaming.... if speedfan is reporting this correctly.
Any idea's please?
Arctic Freezer 64
Phenom II X3 720 BE
Asrock A770DE
Earthwatts 500W
Gainward GTs250
Any idea's please?
Arctic Freezer 64
Phenom II X3 720 BE
Asrock A770DE
Earthwatts 500W
Gainward GTs250
