- 19 Nov 2008
is there a program i can use to control what speed the fan runs at according to the temp the cpu is at. the only thing i got that varies with the temp is cool and quiet and this dose not cut it makes my cpu run to hot and only gets to 80% speed at 65degrees.
i have tried a program called fan speed but this requires it to be loaded up every time the computer is turned on and it takes about 10sec to load up...
do you guys have any good alternatives?
