Hi all,
Quick query:
Using a mATX motherboard that only has 1 chassis fan header but need to connect 3x chassis fans to this header.
Going to use the Gelid solution (PWM 1-TO-4 SPLITTER - CA-PWM-03).
The fans use only 0.2 amps. The motherboard header supports 1 amp in total.
Can I just connect all 3 fans via the fan connectors and not bother with the molex power connector?
Or do I actually have to connect the molex power connector?
Just I'd rather not have all 3 fans running at full speed all the time.
Thanks
Quick query:
Thanks
