fan splitters with different sized fans
10 Jun 2005
Motherboard has two 4-pin PWM fan heads.
Case has 4 fans. 2x 120mm at bottom, and 1x 120mm and 1x 140mm fan at top.
Is it fine to have the top 120mm and 140mm fan shared on a header? Or better to have all 3x 120mm on same header and 140mm on its own header.
Whatever is easiest cabling wise, but the 140mm can spin slower than the 120mm and deliver the same amount of air. I'd be tempted to keep the 140mm on a separate header so you can amend the fan individually.
