Hi
I have a Coolermaster Praetorian case with two 80MM fans located inside the drive cage at the front to cool the hard drives. Now the fans don't bother me when I'm gaming but it's a bit annoying when i'm working on my pc.
Are there any fans out there that will run quieter than the stock fans supplied with my case? I can't use passive hard drive coolers as they will not fit in the case.
Thanks for any help
S
Thanks for any help
S
