Hello, i recently bought a phanteks case and it comes with a built in fan controller which im having a little trouble with setting up.
The problem is i like my fans really quiet, but with the control wire plugged into the CPU header and the CPU Fan speed set to its lowest setting in the bios, its still running at 8-900 RPM, whereas i prefer about 500 rpm.
I tried plugging the control wire into the system fan header but after restart it just went to full speed, although im not suprised as the cpu header has its speed control wire seperate to the 12v accordong to the manual which i assume the fan controller is using.
If anyone has any experience setting these things up any help would be appreciated as ive used a manual fan controller for 15 years so i have no idea.
Cheers.
Cheers.
