Question on fan choice for *pulling* through a rad. I am looking to use a 240mm rad. 58mm thick. However, some of my other cooling system component choices mean I need to run the fans in ‘pull’ (drawing air from inside the case, through the rad, and exhausting out the back)
Do I need good static pressure fans, or good high-flow fans??
I know that pushing air through a rad; static pressure is the way to go. What about pulling through though?
Cheers.
Cheers.
