- 10 Oct 2005
- Nottingham
Hi
I currently have a Silverstone LC16 HTPC case which is suffering a bit from excessive fan noise. Currently it has two Akasa Amber 92mm fans in the front mount points and a Akasa Amber 80mm fan in the side mount point..
Now I have several spare Noctua 120mm NF-S12 fans which come with an extra cable (Ultra Low Noise Adaptor) which you put in line with the fan to drop its voltage (i think) to thus slow it and hence make the fans even quieter.
The 120mm fans are far to big for the case, (and were bought for something else where their stock levels would be fine), so does anyone know if these extra cables that come with them could be used with the Akasa Amber files to have the same effect?
Cheers
Cheers
