12 May 2009 at 19:48 #1 Cheekykid Cheekykid Permabanned Joined 30 May 2006 Posts 1,051 I got this cpu(not overclocked) with a fanless ninja2 and my idle temperature is 48C. Is this normal?
12 May 2009 at 20:02 #2 xxvv xxvv Associate Joined 7 Mar 2009 Posts 52 depends on the rest of the system, is it a htpc/micro system? case? fans? graphics? etc.. lots of factors to consider but just under 50c does seem a little much for idle. heatsink may need reseating.
12 May 2009 at 20:38 #3 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Idealy you need to check full load temps, personaly keep them under 75~ and you will be fine.
12 May 2009 at 20:39 #4 spleenharvester spleenharvester Associate Joined 4 Dec 2008 Posts 1,812 Yeah, you should be fine if they're just idle temps. My A64 X2 5000+ with AK876 sits at about 42*c idle and that's coping fine.
