- 19 Nov 2011
- Edinburgh
Hi,
Am I doing it right? Case is Thermaltake X2. Its awesome. Huge, industrial and simple. My current cooling setup looks like this:
2 x 140mm front intakes, one 140mm at the back and 2x120mm radiator at the top (cpu aio thing)
I was reading about fans, positive and negative pressure etc and now Im not sure if my current arrangment is ideal.
Does it look all right?
Second question - Im using gigabyte z97mx gaming 5 motherboard. all 3 case fans are PWM and Im using custom fan profile in Bios. Its on slowest/quietest setting and yet fans are spinning at 700ish rpm and I cannot slow them further. Fans are ranked 450rpm to 1500rpm (gray Noctuas nf-P14s).
Is it simply impossible to force them to run at 450rpm without getting fan controller or am I doing something wrong?
Thanks
Thanks
