Hey folks, another pre-build planning phase question here. I figure I'm getting near the end of planning my build, fans and cooling.
I've done a few wattage calculations and I got 607w recommended, I had a 750w PSU on the list already which might be dropped down to a 700w (playing it safe and leaving a bit of headroom on the calculations). Anyway, whilst I was doing that I came across the fans section, I hadn't given it much thought other than use whatever I get with the case and maybe a few separate purchases.
http://www.coolermaster.co.uk/product.php?product_id=6640
That's the case I should be getting, it'll house an i5 2500k, GTX 580 card, Asus P8Z68 motherboard, OCZ PSU (750 or 700, depending).
At the minute I've just got some general idea for the fans, which is buy a 140mm and stick that in the front, then use the 120mm supplied with it elsewhere. Other than that I'm stuck.
Oh, I'd also be thankful if you can tell me what other stuff I'll need, I know I need an anti-static wristband for example.
