Hi guys,
Can anyone give me some advice on setting up the fans in this H510i case:
MSI 450i Gaming Plus mobo
AMD 3900X with Scythe SCMG-5100 Mugen 5 Rev.B CPU Cooler
1080TI with Kraken G12 with X52 AIO Water Cooling Unit 240mm (2x120mm fans)
NXZT H510i case
The case has 1 rear and 1 top mounted exhaust fans, I cannot use the rear one as it fouls the CPU cooler so had to remove it. There seems to be only around 20mm space there, maybe could fit a slim one.
I have the left top exhaust fan there as it just about fits.
Now the GPU/Kraken: Which way should the radiator fans be facing? pulling air onto the radiator into the case or how it is now?
Excuse the cables they will get sorted out once I know what i'm doing
NXZT H510i case
you can leave your other fans as exhaust
