I have a fan controller at home. Its nothing special, does the job I suppose, but I have a few queries about fan controllers in general:
1) Can you connect the fan to the controller, then back onto the motherboard again so you can use something like SpeedFan to measure the speeds? i am aware that some fan controllers have fan speed readings on them via an LCD display, but Im talking about ones that don't have these.
2) When I have adjusted the speed of the fan with the twiddley knob, I would expect the fans to slow down to whatever the knob/ dial was set to. However, more often than not, the fan will just slow down and stop, giving the occasional whimper and jump. Would this be due to the fans, or the fan controller?
3) Is a pot diff and a varialbe resistor the same thing?
