Depends what you want the fans to do...
In general, most 120mm fans will be fine. Arctic are the go-to for people on a budget, because they're cheap and almost as good as Noctua... however, Noctua are only the best balance between noise and performance. If you want higher performing fans, there are plenty of better options - Phantex, Corsair, EK Vardar, Lian Li... It also depends whether you want RGB or not.
