Fans for a True
31 May 2005
Peoples Republik of Teesside
I have a Q6600 and an Abit IP35 Pro XE. I'm thinking of getting a True, what fans are recommended (push pull)? I'm not really concerned about quiet.
The sharkoon silent eagle 2000 are excellent fans.
Thing to remember with the TRUE is that the fins are very dense... you do need a strong fan to push the air through the heatsink... for a single fan setup I wouldnt go with anything less than 1600RPM (this can be speed controlled) but at high load to make the best of the heatsink you are going to need some umph... Again a push - pull setup two 1200RPM fans I found gives similar performance to one 1600RPM..
If you really want performance I would look at the delta range, although not the fan OCUK offers as its two powerful to be properly controlled you probably want to look at the 120mm FFB1212SHE model
+1 for the sharkoon silent eagle 2000's, i have 5 of them in total in my rig. 2 on a TRUE and 3 on the case. They do an excellent job of moving air and even at full speed the noise isnt to bad.
