- 19 Oct 2002
- Yeovil
So its time to overhaul my first water cooling build been a few years and the fluid is looking mucky to say the least ! ive a new 240mm rad to add to the system which fits nicely in the bottom ,big phantom case.
It currently has a 360mm rad in the roof with the fans pulling air out ,mid case fan inside, and also a large front fan pulling air in ,so I was wondering is it best to have the new rad fitted with fans on top pulling air into the case or under the rad pushing or pulling ? the case has a pull out filter directly under where the rad is going cheers in advance Q
