Fans for my case mod?
13 Sep 2009
Maidstone, Kent
So, the great fan hunt continues! I am looking for a near silent (aiming for <15 Db) fan that I can use for my progressing HAF 932 mod. My main priority is noise, I hate the noise my current system makes and want to change it. I am looking for something that has similar noise levels to one of CMs 230mm fans (basically you can't hear it until you put your ear to it!). I want to replace the top large fan on the HAF and switch it out for 2x120mm fans to increase airflow. I will also be needing a 120mm exhaust that will be rigged up to my CoolIT Vantage. I may also add a fan in the bottom. I will be using the stock front fan (with a few extra LEDs!) and a 140mm fractal which will be mounted to the motherboard end of the HDD drive bays (help move air through quicker).
My second thing is what makes it more awkward. I would like one with red LEDs. I like the look of the Phobya Nano-G fan's but I don't know how noisy they will be at 1000RPM. If required I can spray the fan and add LEDs but I don't really have the time to do that. If it already has LEDs of a different colour it would be better.
Here is a summery:
  • Super silent!
  • 120mm
  • Red LEDs preferable
  • A different colour LED fan is preferable over a non-LED fan
  • At least one must be able to move air through my Vantage rad
  • Super silent (did I say that already?)
