Man of Honour
- 17 Feb 2003
- Chelmsford
I currently have attached to my triple rad 3 x Scythe Kaze Jyuni 1200RPM which push around 68.5CFM at around 24db.
I'd like to run a push / pull system with some blue LED fans so was looking at installing the 3 x BitFenix Spectre PRO 120mm Fan Blue LED which push around 56CFM under 20db to be installed with the existing Scythe fans or with another brand.
I'm thinking though, do the fans in a push/pull configurations have to match air flow? My thinking is that they should.
So can i run the existing fans with the new BitFenix or choice another matching fan. I don't see the need for 6 x LEDs fans so 3x LED and 3 plain should do.
What do you suggest?
