Just ordered one of these cases. On a review site I looked at, the pictures showed a clear side panel and a 120mm rear fan. However, on OCUk's site, it does not appear to have a clear side panel and only mentions one 120mm fan (which I presume is the intake) and a small 'sleeve' fan.
I did do a bit of searching before posting and saw someone recommend the purchase of the clear side panel for the case, so I presume that is an optional extra. What about these 120mm fans though? Is there a recess at the back for the 120mm, but it just isn't supplied with the case?
Ideally I would like the 120mm intake and another 120mm exhaust, so should I order another 120mm fan? If so, can anyone recommend one?
Also... what is a 'sleeve' fan
Thanks for looking![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
Thanks for looking
