Fans installed the correct way around
6 May 2009
Have these been installed correctly?
Ugly fan side as exhaust. I fear I may have had a brain fart many years ago and they are all the wrong way around :D
The first one and last one are pulling air out of the case. the middle one is pulling air back in, switch the middle one around and you should be good.
You sure, heres a pic from the other side.
I woukd havevthough air is all going one way or another (all front to back or all back to front)
Easy way to keep track of which way air flows through fans is motor mounting frame rails are on exhaust side of fan on 99.9999% of fans. ;)
My Noctuas have arrows moulded into the outer ring on one edge. On the flat spots, but only one one of the flat spots
If in doubt, can't you just stick yer paddles (err hands) in and feel which way the air's being pushed around?
