I have seen some coolers with a fan on one side and another fan on the other side. Presumably this is blowing air accross one way and sucking it out the other side.
I dont know much about overclocking but most CPU heatsink/fans i have had just have a fan blowing down on the heatsink and CPU
Wouldnt it be more wise (as hot air rises) to have say, a 120mm fan on the top of the heatsink, sucking the hot air off it, 1 fan blowing air accross the heatsink and one on the other side sucking the air out. This way most of the heat would be pulled off the metal.
What do you think would happen if i turned my fan on my Scythe heatsink around, so it pulls the hot air off the metal, instead of pushing cold air onto it?
