FANS push or pull on a radiator
Should be quieter if u have them on the inside of the case pulling in fresh air through the rad from the outside. The rad should muffle some of the fan noise.
High cfm/speed/static pressure - Push
Low cfm/speed - Pull
By no means a solid rule but lots of rad reviews seem to show a rough trend in this direction.
If I'm wrong with this can someone please correct me - I'll need to reshuffle my fans.
This ^ or (what i will be setting up this weekend) push from outside and then pull from inside.
You dont wanna be cooling your rad with hot air do you? The main parts of your rig that you wanna keep cool are under water. Your temps will be lower pulling cool air in.
