fans r too loud
arnt them x1800xt supposed to be very noisy ?? a low speed 120mm fan are normally very quiet. also if the freezer 74 is rtunning at full speed t hat will make a fair noisei have mine running at 50%
Are those the standard fans that came with the Phong? If so with the built in rheostats turned down you should'nt hear them. Are you sure it's not the X1800?
You could replace it with a passive Zalman heatsink. Make sure it will fit below your graphics card or anything else that overhangs your northbridge.
Just cleaning the fan normally helps, them chipset coolers have a habit of getting loud.
The x1800xt is also annoyingly loud, i'd bet this + the chipset fan on the mobo are contributing to most of the noise.
p.s. If its a 939 mobo there is no northbridge, its the southbridge... ;)
