Fans running different speed msi 2080
2 Mar 2019
On my new msi rtx 2080 ventus non oc the 2 fans run at different speeds. Both idle
at 900rpm then under load the left fan runs several hundred rpms slower than the right one.
The fans is also a little noiser than my msi 1070 I have owned before. There is a moderate droning noise somewhat louder than rush of air under but only under load. Msi after burner
also displays fan speeds and rpm for each fan individually fan one and two.
I can only think that the left fan makes more noise and msi have running slower to reduce noise. Am a little disappointed as most of the cards I have own only produce vibration or droning noise when running the fans very fast.
Is this normal for the msi 2080 ventus or could there be a problem.
