- 14 Jul 2005
- Birmingham
Hi all,
I am going to be building my own pc and not sure how to set up the fans.
I will be buying this case:
Fractal Design Core 1000 Case & Super Flower 450W FX 80 Plus Bronze Power Supply Bundle= £48.95
Which has room for 1 front 120mm fan, 1 side 120mm fan and 1 rear 92mm fan, all not supplied.
So I was going to buy these fans:
2 x Arctic F12 PWM Case Fan - 120mm= £4.39
1 x Arctic F9 Pro PWM Case Fan - 92mm= £3.98
The motherboard I am getting only has one case fan header.
So my question is how to set up these fans? The description on the larger 120mm fan seems to imply that they can be daisy chained, is this correct?
"The ARCTIC F PWM forward the PWM signal from the CPU to the whole case ventilation system."
and the 92mm fan picture appears to have more connectors coming off it.
So can I join these fans together off the one fan header, or do I need to buy additional equipment? And what configuration of fans do I use for intake and exhaust?
Thanks
Thanks
