fans setup correctley?
11 Jan 2011
Hi, I was wondering do I have my CPU fans the correct way.
First of all the case I have is a silverstone FT02. There a 3 fans at the bottom pushing air up in to the case. There is also a fan at the top pulling air from the case.
Now I have a noctua D14 and both fans are pushing air up in to the heat sink.
The CPU cooler there is a fan over the RAM pushing up in to the heatsink then there is another fan in the middle of the cooler pushing up in to the second part of the heatsink.
Is this setup correctly?
All fans at the front/ bottom should be intakes.
All fans at the rear/top should be vents (blowing out of case).
CPU fan(s) = 1 should blow air into heatsink, one should pull air through heatsink and straight out of Top or Rear case fan, not over memory of Chipset Heatsink.
Hope This Helps.
