- 29 Aug 2010
- Cornwall
Hi guys,
after talking with some mates at work about fans to cool heatsinks and radiators I got to thinking (always dangerous and often dull!).
I believe I'm right in thinking that to cool a heatsink or rad you want a fan with good static pressure? But surely Airflow comes into it too?
Lets suppose you're cooling a radiator in a push config.
Are you better getting a fan that has a higher static pressure even if it's got quite a lot less airflow?
Here are 4 fans with the values pulled from the manufacturer's website (these may be exaggerated but hopefully they all exaggerated by the same amount):
Scythe - Gentle Typhoon (1,450)
Max RPM: 1450
Airflow: 85 m³/h
Static Pressure: 1.3 mm H2O (?, converting 0.051 in mmH20 to mm (from random site on internet))
Noise: 21 dB
Noctua - NF-P12
Max RPM: 1300
Airflow: 92.3 m³/h
Static Pressure: 1.68 mm H2O
Noise: 19.8 dB
Akasa - Apache Black
Max RPM: 1300
Airflow: 97.74 m³/h
Static Pressure: 2.64 mm H2O
Noise: 16.05 dB
Enermax - Apollish
Max RPM: 1700
Airflow: 121.93 m³/h
Static Pressure: 2.03 mm H2O
Noise: 15 dB (Really? @ 1700rpm?)
Assuming these figures to be right, what would you go for?
The Gentle Typoon doesn't seem to be up to much, but I've seen them recommended before.
The Noctua, while better than the Gentle Typhoon doesn't seem that good either.
Which leaves the Enermax and the Akasa. Noise levels are similar. So the Apache has about 80% of the Airflow of the Apollish, but the Apollish has about 77% of the Static Pressure of the Apache.
So which would be best?
What about in a pull config, which is apparently better for low RPM fans (is 1700rpm low?), does static pressure matter as much then?
I've currently got Apache Blacks, but wondering if I should change some/all for Apollish or something else?
Thanks for your time and advice/opinions/feedback.
Max RPM: 1450
Airflow: 85 m³/h
Noise: 21 dB
Noctua - NF-P12
Max RPM: 1300
Airflow: 92.3 m³/h
Noise: 19.8 dB
Max RPM: 1300
Airflow: 97.74 m³/h
Noise: 16.05 dB
Enermax - Apollish
Max RPM: 1700
