Fans, talk to me, need a few different sizes
22 Nov 2010
Kettering
Hey all,
I have a lancool 215 with dual 200mm fans up front, two 140 EK Vardar for my 280 AIO and a single 120 at rear.
I'm wanting to replace them with better quality and "silent" fans to keep my 5800x and 3070ti FE cool without being loud.
PC is in my bedroom, I often play when my partner is sleeping.
I also want RGB so it will link up with my b550 strix motherboard
Any recommendations?
Just check if the noise isn't mainly from the rear exhaust fan. Quite often they were the noisy ones in my builds.
As you're using 2 large fans as intake, and 2 X 140, which I guess are exhaust, not sure the rear fan is really required.
The beQuiet Silent Wings would be great for the AIO, but no RGB, unless using one of those RGB rings.
Usually push pull is just a waste, but as you're targeting as silent as possible, it may help.
I shall check that out thanks, I don't have room for push pull, I'll try unplugging the rear fan and see if temps change at all
