Ok, some opinions and advice would be helpful...
1) I Need some new paste - I've always stuck by Artic Silver 5 in the past but is there anything better these days?? Thermal paste reviews are hard to come by it seems.
Not looking to pay megabucks (and that liquid metal pro stuff is well off the menu), but not adverse to spending a little time applying it properly for best results (hence the old AS5 choice).
Its to be used for pretty much everything - CPU/HSF, NB & SB new mountings, GPU HS remount and even on my new RAID Card lol.
2) Fans! I'm after some new fans for my case.
Requirements are nice looking, decent airflow but quiet, and also in 120mm and 80mm versions. They'll be used both as case fans and I'll be mounting a couple on my 80mm spacing NB, SB and RAID Card heatsinks.
I really like the look of the Enermax Clusters (White LEDs look good) and have always liked the Sharkoon Silent Eagle fans, again any comments or others I should be thinking of?
Case wise, they'll be going into my Lian Li A70B thats going to get a side window modded into it.
