Hi
Since I bought my case (Corsair 500R) I haven't done any upgrades if it comes to air cooling. I'm planning to replace all fans and add the bottom and top fans.
I'm little bit confused now, is it better to control them by Fan Controller or motherboard ? If I'd choose motherboard then I need to connect all fans to PWM Splitter and then to CPU Fan connector correct ? And these fans will be running based on the CPU temperature and RPM right? What is the best solution, how to set this up properly. All advice much appreciated.
Thanks
Thanks
