fans with TRUE
15 Oct 2008
im upgrading from my arctic freezer 7 pro, i want to stick to air cooling (cant be bothered with water atm) so chose the TRUE.
before i order, what 120mm fans should i be getting with them? and should i get 1 or 2. i suspect they clip on just like the artic freezer 7 pro so that will be a doddle. only question is what fans to get?
i have an e8400 c0 stepping and i dont have a fan controller
I just bought 2x standard cheapish fans. I plan on running them push + pull towards the rear extractor.
I figured that was best after looking through various reviews of the true black.
If anyone knows any better I will be interested aswell.
thx bustage that makes sense
also does anyone have a TRUE running on my motherboard (see sig) as it has a large NB heatsink that i have to check cpu heatsink clearance for.
If youve got the TRUE and you want extreme overclocks, the sharkoon fans are excellent, 2000 rpm models for a quad, highly clocked, got 2 on my TRUE and q6600 @3.8ghz theyre very good
Very good combo, im getting rid of the q6600 soon. fancy getting an E8600 and trying for 4.5ghz on air cooling.
