we'll no I don't need to be able to select it, I need it to set to a very low voltage, 5v max. Maybe below if the fan will spin up. But what I do want is that one controller to control all 4 fans. 3 Rad 1 on res. I don't need a large amount of air movement just a little.mishima said:Just a question, do you need a fan controller to chose whether you want the fan running on 5v, 7v or 12v? How do you choose?
mishima said:Sorry lol, that was an independant question what I was asking to others![]()
So do all fans run @ 12V?gt_junkie said:AcidHell2 - you can hardwire the fans to run at 5v constantly if you need them too! If you search on google you'll find what you need. There are even 7v mods. It's a simple case of removing molex pins and swapping them.
Just take your time and double check everything and you should be ok!
gt
Edit: Here's one - Linky
