is there a large difference between any of these any recomendations They have to be 90-92 mm as i really do not want to have to mod the case to fit 120's in. the first fan in my thermeltake case has died so i'll want 4 of them to replace them?
Sort By Name Make Stock Price qty
AcoustiFan DustProof Quiet 92mm Fan - 3 pin
A new range of premium quality, ultra-quiet dust-tolerant multi-application cooling fans for PCs. These fans have been designed to be quiet and stay quiet!
AcoustiFan 10+ in stock £14.99
(£17.61)
Akasa AK-184-L2B Amber Ultra Quiet 92mm Fan - 3 pin
The distinctive amber colour rotor blades are designed with low air impedance which gives the ultra quiet acoustic experience.
Akasa 10+ in stock £5.99
(£7.04)
Coolink SWiF-922 92mm Case Fan
Not only are the Coolink Silent Whisper Fans great value for money but they also come complete with a fan controller that fits into a spare PCI slot at the rear of the PC.
Coolink 5 in stock £8.99
(£10.56)
Papst 3412 N/2 GLE 92mm Fan - 3 Pin
The Papst 3412 N/2 GLE fan is characterised by a high-quality finish. The fan also incorporates a particularly silent motor developing a noise level of only 23 dBA.
Papst 6 in stock £4.99
(£5.86)
Papst 3412 N/2 GLLE Silent 92mm Fan - 3 Pin
The Papst 3412 N/2 GLLE fan is characterised by a high-quality finish. The fan also incorporates a particularly silent motor developing a noise level of only 12 dBA.
(£5.86)
Xilence XPF92R Red Wing 92mm Quiet Fan
This black & red 92mm case fan cools your PC components with this Xilence fan. It offers extremely good price-performance ratio and cools your computer efficiently at an ultra low noise level.
Xilence 9 in stock £3.99
(£4.69)
Zalman ZM-F2 92mm Silent Case Fan - 3 Pin
The Zalman ZMF2 92mm fan offers high performance with minimum noise.
Zalman 10+ in stock £5.99
(£7.04)
(£17.61)
(£7.04)
(£10.56)
(£5.86)
(£5.86)
(£4.69)
(£7.04)
