4 Dec 2007 at 17:13 #1 alex737 alex737 Associate Joined 23 Nov 2007 Posts 29 I just bought 4 silent eagle 2000, to be fitted on the side of my CM stacker 830. Which way should the fans blow the air, inside or out of the case?
4 Dec 2007 at 17:30 #2 Trusty Trusty Soldato Joined 12 Mar 2006 Posts 17,720 Location Boarding the Nostromo I would have thought blowing cold air onto the motherboard would be best, then the exhaust fan will pull all the cold air out.
4 Dec 2007 at 19:28 #3 alex737 alex737 Associate OP Joined 23 Nov 2007 Posts 29 Cheers, I thought so. I so a diagram that was showing the fans exhausting the air out, so I decided to ask. Thanks .
