Fans.
19 Jan 2008
Sunny Wales.
Im goin to replace all my case fans 8 in total with some quieter ones. is there any differace between the sharkoon 1000 on this site and the golf ball ones other than the look? would there be a better choice? a lot of ppl use yate loons but tbh i like the white of the sharkoons.
I thought they were one and the same (white/golf ball/dimpled effect on fans). Sharkoon Silent Eagle?:confused:
1000 Sharkoons are great case fans, but for the money you can get 2 yate loons and if it has to be white then spray them :)
