I am looking for some quiet, but high airflow fans for my case.
It is a CM 690 II Advanced. I want 2x 120mm fans for my H50 and 3x 140mm fans. The reason I am doing it is because the stock ones are driving me insane.
Can anyone recommend any? I am looking to spend around £25 for all of them.
Cheers
Cheers
) Yate loon range they cost under £5 each, if you get the high speed ones they will not be silent but believe me no fans are (dont believe the specs they lie!!!) get 5 high speed yate loons and a fan controller then get the best of both worlds, high airflow when needed and silent when not...
