Fans!
7 Mar 2010
I've been looking for ages for the best fans that look good
I need 2 120mm, 2 80mm and a 92mm. Got a bit of a blue black and white theme going on in the case so something with these colours would be awesome.
I know fractal design have a full range but can't find any reviews for them?
Also looked at noctuas, but they're very expensive and their colour scheme is pretty different to what I have but do look great..!
What to do.. any help would be lovely, cheers
Not sure on 92mm or 80mm fans but if you are going for a specific colour scheme have you considered painting the fans yourself? That way, the 80mm 92mm and 120mm will all be the same colours.
