Fans
28 Nov 2010
Do i get yate loons or scythe gentle typhoon.
These will be on a pa 120.2 and a hardware labs 360.
The thing that puts me off the scythe fans is the grey blades but are they really worth it.
Gentle Typhoons seems to be considered pretty much the best on the market at the moment for radiator use, because of their high static pressure. The 1450rpm models seem to be the sweet spot as they can be volt controlled all the way down to less than 300rpm with the same noise levels of the slower fans.
^^ Oh no now your confusing the matter lol.
Its gone from two to three. I also managed to find a tut in regards to taking the fans apart seems simple enough.
i've got 5 vipers running at full in my pc at the moment and they are quiet.good cfm and static pressure.supposed to be good rad fans
Cheers for the replies guys.
I think its going to come down to how much $$$ i have in my pocket at time of purchase.
There is a big bifference in spending over £100 on fans and spending short of £50 on the same amount of fans.
If i was going to go for yates which ones would be best i have been lookcing at these and putting them on a controller D12SH-12.
The yate loons are good fans but they are cheap and you get what you pay. They flow reasonable air and are quiet but they arent as good as gt's or vipers. Though gt's do have a higher static pressure compared to vipers though.
Also if you are going to painting them I would go for loons or gt's as you can take them apart. It is just a case of taking the cap off from the shroud and popping off the c clip to remove the blades. I know if you search youtube there is a video of someone taking a gt apart.
Yeah i have yates at the moment but only 3 of them and they have never skipped a hear beat and i have taken them apart multiple times to clean them.
Also can someone with gt's confirm they only need 0.083 amps to operate if that is the case it means i can almost power 31 of them on a single channel which does not seem correct.
I have a lamptron fc5 v2 btw at 30w per channel. So by my math its 12 x 0.083 = 0.996 total watts to power 1 fan. Watts per channel divided by watts for 1 fan 30 / 0.996 = 30.12
Well by my maths they need 0.996 watts to power up to 12 volts so max speed and 0.29 watts to power on at 3.5 volts but i may be wrong.
