?? Fans ??
22 Oct 2010
Pontefract
As my system spec slowey get better the temps inside my very small CM 360 case are getting hotter. on Monday i will receive my Radeon HD 6870 and i expect that to pump the temps up more. i am thinking of adding more fans.
right now i just have 1 120mm exhaust. i would like to use all the fan point on PWM i have room for 1 x 120mm, 1 x 92mm and 3 x 80mm, i plan on fitting a A4 size plexi window so i want the fans to function well but look good and match.
the question in what fan can i get that look good, function good but as i need 5 i dont plan on spending £60 on fans on fans
i would like white, green or blue fans i dont want to paint them as you end up with a unbalanced fan
